1 - 4 of 4 Posts
Just the other day i was rushing to school, did a 180 at the gas station and filled up. When i started back up, the lifters were ticking, but usually go away in a few seconds. This time it took a bit to go away, and when it did, it ran really crappy. So i said, aww **** stuck lifter!? So then i look under the hood, and i see antifreeze leaking over the #4 coils from the heater hose. Great.. Then i get the code for #4 cyl misfire, hmm okay. So i check the basics, check the spark. Sparks good, check everything and i cant figure it out. Totally stumped after replacing a few plugs and coils, i decided to go back to the lifter problem. FInally get down and dirty tonight, pull my valve cover off. What do i see? My rocker arm.. sitting on the bottom of the head. It had fallen off the lifter and valve somehow, and on #4 cylinder. What are the odds of that happening? I think it happened because the lifter got worn out, didnt give enough pressure and allowed rocker to slip. Thats the only reason i can come up with! So i am half way into putting it back together, WITH A NEW LIFTER. I just ran out of steam, i got sleepy tonight at 2am lol. So hopefully tomorrow it runs like it should! And doesnt happen again..
Hooning
dayum you found what out read pretty fast, I've had about to random misfires this year, first an injector died on me, next a spark plug gets over tightened and colides with piston. good luck with fix
Yeah i put cams in the engine with stock springs and lifters, but the ticking happened at idle speed, and thats when i assume the rocker fell off. If it had fallen off at high rpms, oh damn. Who knows what it would have done
1 - 4 of 4 Posts
