1 - 10 of 10 Posts
im taking my supercharger outand i want to tune on E85,anyone done this running N/A car how much HP you pick up over 93? mine was making 330 rwhp B4 blowe on pump gas 93.
Discussion Starter · #2 ·
by the way ill have my V2 and anderson power pipe for sale.... i gotta found out what they go for and ill post it for sale.
Head Unicorn
200
Priest of the Car Gods
N/A you'll lose power on E85 over pump gas unless you have crazy-high compression. The only advantage E85 has is its octane rating; it has significantly less energy density than gasoline or diesel.
If you're looking to run E85, your better bet is to keep the supercharger and take advantage of that higher octane by cranking up the boost.
US Air Force (retired)
Yes, and under high compression conditions it might make a difference. But with 10:1 compression ratio I would think the disadvantages would outway any gains that you would have.
1 - 10 of 10 Posts
