1 - 2 of 2 Posts
I have a 2004 Cobra with a 2004 Mach 1 motor , I recently installed a On 3 Performance Single Turbo Kit , Also converted to return style fuel system & put a twin 65mm Throttle Body on , Car starts but wont Idle , Runs like crap . I downloaded a Tune that should be close enough for it to Idle, even tried the old N/A tune in it but there was no change, If anyone has some advice on what I should check or look for it is welcomed ,,,, Changed the plugs , could smell the gas fumes in the exaust & it was white , car never smoked before.
Thanks for all the advice Guys. I think Ive got it figured out. Not a Good Idea to Put Bigger Aftermarket Throttle Bodies on these MOD Motors, Also Fuel Pressure Was Too High at Idle, It was 55psi ,Should be 40psi ,,,Increases with Boost
1 - 2 of 2 Posts
