1 - 11 of 11 Posts
Ok so I am getting ready to order more stuff soon. Right now I am trying to stay around 300 bucks for my next upgrade. First of all while I will make a trip to the strip here and there I plan to road race and autox more often. Even more time will be spent doing some spirited driving on whatever curvy roads I can find. So I just don't know what I should do first. Because I realize that the mods will all work best in combination. And that will come with time. A quick question is..I have heard if I plan to hit the twisties more than the strip I should forget about rear upper control arms. Is that true? Here are some thing I am looking at... Also for control arms I must be able to have a spring perch and sway bar mount
New front brake rotors with Hawk HPS pads SS lines and some good high performance fluid. Cost about $290 give or take a little.
UPR upper and lower control arm package $299 I picked this one because I hear I want the spherical type bushings where possible ( Jazzer can comment ) But I really don't need the adjustability I don't think and not sure how these compare to MM's parts Link 1999-2004 Ford Mustang Pro Series Adjustable Control Arms Package - UPR Products
Sub frame connectors from MM About $169 plus shipping and welding at $94 an hour labor rate.
MM Rear lower non adjustable control arms HD Rear Lower Control Arms, 1999-04, with perch, swaybar [MMRLCA-5] - $259.95 : Maximum Motorsports Performance Mustang Suspension Store, Buy Now! $259.99
MMR Upper control arms $129.95 Rear Upper Control Arms, solid axle, 1979-04 [M-5500-A] - $129.95 : Maximum Motorsports Performance Mustang Suspension Store, Buy Now!
Also if I do upper and lower arms I should remove the quad shocks correct? If you guys have other suggestions in this price range that would be great. Also if you want to recommend a paticular brand or something please link to it and if possible explain why I should go that route so I can learn something while I am at it. Thanks as always!
My .02,
Drive a few events stock and find out what you don't like about the car and remedy those issues. When I open tracked my car it was apparent that there was excessive wheel hop in the rear and serious understeer overall. I ripped out the entire suspension and installed a Maximum Motorsports Max Grip box along with a set of Wilwood SL6/DL4 big brakes.
The 'stang has now been transformed into a go-kart!!:D
All I need now is to find a good deal on a Termi motor and I'm set!!
John
I you are going for corner carving than forget the uppers. A few of thr rear end mods even eliminate them all together. If you havnt already replaced the shocks, struts, and springs, I would start there. Later as money alots, Watts link or 3 link, and bump steer
I'f you don't have subframe connecters i'd get those.. because it will stiffen up the chassis and help you in turns and the 1/4 mile. if you are a corner carver. coilovers would be your best bet eventually. and don't get uppers if your going with a torque arm and watts link because it eliminates the need for uppers.
Upgrade for the future not for the now.
Jazzer sent me a link of a sticky from a brother site. it pretty much told me everything.
Abyssinian of AX
Damn.... didn't I already respond to this thread? I see no posts by thyself :(
For $300, I say FLSFC's unquestionably and indubidubly :yes
Stay away from the UCA's you have linked for $129, as they suck for your needs!
I like the UPR UCA's, but would forgo them and go PHB or WL and torque-arm to properly tame that rear end of yours :confused:
Jazzer :)
Abyssinian of AX
01mggt,
Check out this link:
Suspension Guide - The Mustang Pitstop
This will explain everything!
John
pssst... that is a copy of my thread combined with that of our own ModMustang97GT here on MM's. I actually attained permission to use his info and add my own. I am not sure what the guy on Pit Stop has added, but he better check back to mine as I update it frequently :yes
Jazzer :)
I KNEW THAT LOOKED FAMILIAR!!!
John
If you do not have sub frame connectors. That is the most important thing to get. Street/strip/track, you need subframe connectors. The subframes make everything work together, and your stock frame is weak and flimsy. And under spirited driving, the frame will eventually warp and deforme.
Boost gets you laid
torque arm/panhard bar ftw!
1 - 11 of 11 Posts
