Backfiring through the intake or popping through the exhaust?the mass air is connected when it starts it will run if u give it throttle but it backfires
yes.is the fuel pressure regulator hooked directy to an intake vacuum?
The nipples are called pintle caps. You can get away with a slightly broken one or cracked ones, idk that i would just go without one. But I don't think that is your problem.something else though when i took out the injectors like 3 or 4 of the plastic nipples on the ends were dry rotted and broken so i put them in without them...would that be causing this too??
ya i bought some injector filters from that guy he is a great seller only one i have ever added to my faverote sellers.The nipples are called pintle caps. You can get away with a slightly broken one or cracked ones, idk that i would just go without one. But I don't think that is your problem.
You can pick them up locally at Napa for about $4 per injector. part # CRB212085
If you can wait longer, there's a guy on ebay that runs a storefront called mr. injector that will sell you all 8 for $18.
Either way you go it gives you new o-rings, but the ebay storefront gives you new filters for each injector and it ends up being a lot cheaper if you're doing all 8.
it sounds like you messed up the firing order
i know the fireing order is okay
lolno i had the fireing order going clockwise insted of counter clockwise
