1 - 11 of 11 Posts
So I changed my thermostat and thermostat housing gasket yesterday filled it up with antifreeze and drove around no issues. Well today I smelled antifreeze so I checked and it had overflowed temp stayed normal. So I cleaned up the mess and continued to drive beat on the car a little and no more came out. When the car was hot the coolant level was where is should be, when the car cooled down the coolant level dropped to a little under halfway down the reservoir. Should I add more coolant or just leave it?
Where did the coolant come from? A leak, or are you saying it came out of the overflow?
Might have been air bubbles in it. Let the thermostat cycle a couple of times with the radiator cap off and make sure it's full.
i think there are cold and hot level lines but i could be wrong, id have to go look. i always add antifreeze when its cold so id say wait until its cold then fill it to the line. also make sure its not leaking from the gasket, you cant really over fill it unless you go past the line on the overflow so just make sure all the air is out and the gasket isnt leaking, fill it up and you should be ok.
Came from the overflow from under tha cap. Where should the coolant level be when the engine is cold the the mark on the reservoir? If so how does that leave much room for expansion?
leave it alone for a few day's (watch it doesnt get much lower though). most likely just had an air pocket that worked it way out (ie. the small coolant loss) & is stabilizing itself now. check it over the weekend & top it off & you should be good.
keep a gal of antifreeze in the trunk if your worried. I'd give it till this weekend & check it/top it off (if you drive the car every day that is).
1 - 11 of 11 Posts
