1 - 19 of 19 Posts
PhD in Procrastinology
Just found this on CL and it seems like a good deal. If anyone knows, is it the 2.97/.50 ratio or the 2.66/.63? Also, will this work in my car with a different BH, DS, and crossmember? Finally, is the shifter in the same spot so it will actually fit?
Viper Srt-10 T56 Transmission Perfect Condition
I'm planning on getting a T-56 mag. This is a pretty good deal
Resident Know-it-all
Its the 2.66 .5 trans if its a true viper. Would need a custom input and adapter/front cover to work proprly. Yes shifter is same spot. My verts T56 was a viper conversion from d and d. Call them and ask for Joe, he can tell you what you,ll need to make it work.
Plus dude, even though it'll cost a lot, it's stronger than a magnum tranny. I've seen stock viper t56s go 8s.
Sent from my galaxy s II
$1200 is chump change for this thing. I talked to the guy and he said it came out of a Viper so SURELY he's not lying, lol. I think I'm going to get it. You sure it's stronger than the mag?
Yes. Positive.
Viper spec t56s have held 1000hp+
Like I said... A viper with a stock clutch and stock trans went high 8s at 165 or so. He was launching on slicks too so it's not like he had a 2.0 60 foot, lol.
The magnum is good to 700-750ish horsepower. While that's plenty for pretty much most people, the viper spec is still stronger. Plus a long first gear is pretty cool :lol just doesn't help your 60 foot :lmao
Discussion Starter #9
Talked to Joe at D&D (thanks nx) and he said it'll cost a LOT to make it fox ready. He said something about only the middle case being able to be used. He also said the mag can/has handled 1000 hp, they are just conservative on the rating.
Sent you a quick question nxcoupe. Sorry for the the irrelevant post :D
And yes they're expensive...
I believe D&D has a whole conversion kit (tranny/bell/driveshaft/flywheel etc) for like 7-8 grand.
Discussion Starter #12
$4300 for everything. He said the easiest T-56 to convert of the 3(Viper, GM, Ford) is the Ford for obvious reasons. He did say that with the Terminator tranny I wont be able to have a speedo.
Thrbfirs..... Meat Eggs
NO, not that kind of electronic speedo. That's what the quotes were for. It doesn't use a trans input. And just for future reference :piss2:Eagles :piss2:Cowboys
Signed,
Vikings Fan
(Even though we need to drop Leslie Frasier and he can take Christian Ponder with him too.)
Between him and Jarrod Allen showing love for the game above a paycheck, I love my team. And knock on wood, the ball dropping AP seems to be well behind us.
Go Bengals! Well at least till sunday ruins our hopes and dreams, lol. Ill check out your pm.
1 - 19 of 19 Posts
