1 - 10 of 10 Posts
I broke the retaining clip on the throttle body actuator wire connection (so now the connector will slide off). Does anyone know where to get this connector? It plugs into the drivers side of the TB. Will upload pics if necessary
gtscrewd
could go to the junkyard and try to grab one i remember that connector it was kinda tricky
Watch n learn
If its not falling off it should be fine as it is, replacing the connector will require cutting and splicing of your harness unless you know how to swap the pins over. Harness should be available at the dealer or any jobber/wrecker.
My son did that on an injector connector. I took a small wire tie and fished it between the wires on the connector and around what I could on the injector to keep it together.
FBGM
Just get some big shrink wrap and a heat gun, done no problems.
Discussion Starter #10
Thanks gents...found a junkyard dealer on eBay who says he's going to try and find me one. Hopefully the price is good
1 - 10 of 10 Posts
