1 - 3 of 3 Posts
I just bought a 2003 cobra a couple days ago. But there seems to be a few problems with the car. When turning the steering wheel, there is a clicking noise coming from the front end. What could it be?
Also, the front end passenger side is 3/4 in. lower than the front end drivers side. The rear of the car is even. Is it a bad spring or strut? The frame of the car looks good. With the car leaning like it does, could this be causing the clicking noise?
a.k.a. Racecougar
The clicking noise is likely a failing balljoint. The lean could be a broken spring, bad strut, bent frame/control arm, etc. Honestly, you need to get under there and see for yourself. Diagnosing the problem(s) is a shot in the dark over the internet.
Agreed, and if you don't see anything: Jack it up, remove the wheel, and take a couple of pictures and post them up in this thread. Maybe one of use might be able to spot something
1 - 3 of 3 Posts
