1 - 5 of 5 Posts
I have 02 Mustang GT No start Caint here fuel pump I think it's the theft system.My theft light blink's slow until I turn engine over then blink's fast I can leave key on for ten minutes and light will go off until I try to start again then it blink's fast again What would you advise me to do If I spray gas in throttle body car will start for a few seconds and then die so I don't think it is my key Please Help if you can
That’s a pats issue
If I connect hot wire and ground to the pump it will come on but when I connect plug behind gas tank It want come on when I turn key on I have 12 volts at inertia switch but not at pump will pats system cause that
Pats has to be dealership
1 - 5 of 5 Posts
