Hey Ryan, do you use DR's at a lower pressure at the track and run them on the street at a regular pressure (25-30psi)? I am looking for a tire that will hook decently, but still perform in turns. Are you using a BFG, Hoosier, etc.?
Traidmarx, Did you replace the t5 with another t5 or a tremec, etc? I know the T5 is weak and I'll probably end up replacing it sometime. Is it easy to switch to a 6 speed tranny, T56??? With the 3.73's at highway speed, it would be nice to have a 6th gear.
Is the mass air swap easy to do? I got a wiring harness plug and some instructions from the guy I bought it off of on ebay. I see a wire needs to go to the computer and I'll have to get a wiring terminal where it snaps into the computer wiring harness according to his directions. Anyone do this recently and have some tips or instructions?
Thanks again all!!
Thanks again all!!
