1 - 3 of 3 Posts
I have 92' LX 5.0 that I want to start installing some more after market parts.
What is already installed on it is tubular upper and lower rear control arms, subframe connectors, polyurethane bushings, bbk caster camber plates, cold air intake, 1 5/8 Shorty headers and a msd blaster coil.
In about two weeks I'm going to rebuild the 8.8 and install a Ford racing trac-loc.
So what are some good bolt on performance parts and traction upgrades around $200-400 I can install to get some more power and traction? This winter I will be rebuilding the motor and the aode tranny.
new rear gears with the trac-loc
92 should be an AOD not AODE and talk to silverfoxbody on here about building you a bullet proof trans and hard shifting valve body.
1 - 3 of 3 Posts
