1 - 7 of 7 Posts
Im installing steeda UDP's...so far so good. I was just wondering if you reuse the factory thick washer that was on the crank bolt when u install the new crank pulley???? I got a new crank bolt, but I'm stuck until I figure this out. Thanks
thanks you!!! was stuck on this step and running outta time
You put new RTV sealant on the key, right?
Yes. Put new rtv sealant on. Everything went together without a hitch. I water pully bolts came off with a ratchet and crank bolt with a breaker bar...not too shabby. Thanks again Shane!:D
Tomorrow I tackle the steeda upper control arm install...
1 - 7 of 7 Posts
