1 - 4 of 4 Posts
I need to know if I have just really bad clutch chatter or a transmission/clutch problem. Everything seems to be smooth shifting, clutch pedal feel, clutch engagement etc. I have an annoying noise that comes from the tranny when the clutch is pushed in but that's it. Once the pedal is released the noise stops. I don't have any shaking or vibrating in either the pedal nor the shifter. Not sure if I should be concerned about any problems or if I'm just over thinking the noise. Any help or advice is thanked in advance.
Sounds like a bad TOB.
That was my original thought but pulled the tranny and replaced already and the noise still hasn't gone away
Starting to thing its gonna be the input shaft bearings. The noise is starting to happen with or with out the clutch pedal being pushed in.
1 - 4 of 4 Posts
