1 - 4 of 4 Posts
2005 Mustang S197 GT,
*Vortech V2 @10psi, Stock 5spd. Tremec T-3650, Steeda Short Throw.
While pulling in, I lost first and second gears. (3-R were fine)
Tried a couple of times, then it jammed into first.
Once it popped out of first, 3rd-Reverse locked up.
**(cannot go into 3-R even if clutch is engaged)
Now I can put it into 1st or 2nd without using the clutch but the tranny still remains in neutral, no matter the placement of the shifter handle.
Thoughts??? Looking for some guidance of where to start so I could possibly complete the fix myself; before just shelling out cash for a new tranny or a tranny repair shop.
Possible thoughts of mine: Syncro? Shift Fork? Tranny f*****? Clutch Problem?
---Thanks for reading, anything can help.
PM me with serious inquiries.
John Frazier
First thing I'd check is the arm that goes from the trans to the bottom of the shifter lever and see if it's still attached. A few people have broken the little extension that comes off that shaft that goes through the bottom of the shifter and there's also the possibility that the nut just came loose that holds it to the shift lever.
Eat Springs, **** Valves
About 3/4 years ago I had a similar problem with another car. Couldn't get it into gear unless the car was turned off. It was bad clutch.
Mine will not go into 3-R AT ALL.....
and 1 and 2 it will go into the slot but not gear
with or without clutching
1 - 4 of 4 Posts
