1 - 8 of 8 Posts
Hello everybody.I getting ready to build my first 5.0 liter ford i have built engines before but this is my first 5.0. I would like to get close to 350rwhp out of it . The car is a 93 lx 5.0 with the aod i have already put a electric fan setup on i underdrive pulley's 65 mm throttlebody and aftermarket headers,3.73 gears and a bigger fuel pump. I plan on pulling the motor i have a msd pro billet distributor edelbrock performer heads with 2.02 valves a c&l maf meter for 24# injectors and a trick flow street burner intake. I need help with picking the right cam and other odds and ends to get close to 350 rwhp.If the intake is not that good i can get another. Any help will be greatly appreciated.
Nothing you listed will get you any where near 350 to the wheels..........
Sloppy aod...
Sub par edelbrock rpm heads....
etc
Get rid of the above before starting your build....
you will be around 250 hp with that..
ditch those heads get some trickflow heads and a good cam and intake the rest you can get over time but try to get a bigger throttle body at least 75mm
1 - 8 of 8 Posts
