here is a copy and paste off the 5.0 website:
Dragon Performance Parts
Among its array of modular Mustang intake components, Dragon Performance Parts [(270) 791-8654;
www.dragonperformance.net] had this Two-Valve intake on display at PRI. A direct replacement for '99-'04 Two-Valve Mustangs and '96-'98 Two-Valves converted to PI specs, this intake features a removable plenum cover and generous wall thickness to make easy work of porting for increased power. The intake is said to boast generous radii and optimal taper for improved airflow not only at the peak, but over a broad rpm range. Dragon reps say Anderson Ford Motorsport was testing one of the intakes before its final release so it should be available by the time you read this.
