1 - 11 of 11 Posts
MM's Mad Scientist
It looks pretty bad ass, but it's not going to clear the problem up witht he stock plenum. You are still going to be breathing through the same size outlet into your intake.
mm's nitrous mod
if you can utilize it, the velocity of the air would be screaming thru the intake. even with the small opening, there will still be a greater volume than the single blade set up.
1 - 11 of 11 Posts
