Hey guys. I'm sure this has been asked a lot but I'm just trying to get an idea of what I'd be putting down to the wheels. It's a 93 Mustang GT, mod list below.
Engine/Trans:
Procharger
TrickFlow Upper
TrickFlow Lower
BBK Shorty Headers
355's
Procharger FMIC
255 Fuel Pump
E-Prom
40lb Injectors
70mm Throttle Body
10 Psi Pulley
Stealth TT BOV
B&M Shifter
Steeda Clutch Cable
Aluminum Driveshaft
Flowmaster 2 Chambers
Gutted Cats
Flowmaster Tailpipes
Electronic Fuel Reg.
X-Pipe
Mild Cam
King Cobra Clutch
Suspension/Wheels/Chassis:
Kenny Brown Lower Tie Bars
Full Subframe Connectors
Kenny Brown Stg 3 Springs
Koni Adjustable Struts
MSD Ignition Boost Control
Kenny Brown Strut Tower Brace
Camber Caster Plates
Slotted Front Rotors
17" Cobra R Wheels
1/4" Rear Spacers
Bolt-In 4pt Cage
Ignition/Timing:
MSD Ignition
Boost Retard
Engine/Trans:
Procharger
TrickFlow Upper
TrickFlow Lower
BBK Shorty Headers
355's
Procharger FMIC
255 Fuel Pump
E-Prom
40lb Injectors
70mm Throttle Body
10 Psi Pulley
Stealth TT BOV
B&M Shifter
Steeda Clutch Cable
Aluminum Driveshaft
Gutted Cats
X-Pipe
Mild Cam
King Cobra Clutch
17" Cobra R Wheels
1/4" Rear Spacers
Bolt-In 4pt Cage
Ignition/Timing:
MSD Ignition
Boost Retard
