1 - 17 of 17 Posts
What do you think???
I Torqued the studs that butt up against the main cap to 10 ft lbs and then the jam nuts to 10 ft lbs also. Will it make a difference if I did it with the rearend in the air and no jack under the rearend?
Bought it on ebay for $123 plus 3 qrts of 80w-90 $16 and friction modifier $5, $144 total.
Who Care's ... Boost It!
Damn dude, that's a steal. Jegs has some for 159 off the bat so that's a hell of a deal. Looks nice. Now paint it ;-)
No paint, going to leave it aluminum color.
Not a bad deal. I bought 2 (Summit Brand) at Summit's Akron store last spring for $100 ea. They had them on the floor as manager's specials. Should have bought more. As far as torqueing the bearing cap screws, you should be fine although I think I used a little higher torque on mine. Looking for my build sheet now.
5 ft lbs is the recommended torque for bolts that support the bearing cap, 10-15 ft lbs for the jamb nut.
Anymore than that can distort the bearing caps and cause premature bearing failure. If you used more, you'd better back it off.
wow that looks sweet looking, i think painting it would kill the hole affect
Discussion Starter · #13 ·
Discussion Starter · #14 ·
how do you like the 3.55's
cover looks great
I like them a lot, there a good all around gear especially if you do alot of interstate driving, 80 mph at 2500-2800 rpms.
Discussion Starter · #15 ·
I went ahead and changed the torque to the specifications that you supplied.
1 - 17 of 17 Posts
