Tire pressure should be based off of the vehicle, so you can run the same tire psi as you do now. No worries, go for it.
Amen ...The sensors don't need to be reprogrammed. They will only go off when ur psi is lower than mid-20's. The psi u run has to do with what tires u have... Not what ford says for factory settings. the proper Psi has to do with vehicle weight, and tire load index, and tire size. Proper psi for my car is 42 in front and 38 in rear.
correct... If ur running factory 17inch p-Nero zero pirelli's32psi cold!
