1 - 20 of 42 Posts
ok i have a 91 notch that i picked up for cheap. i am doing a cheap build just so i can get the car running so i dont lose interest as its already set for a while.
i picked up a "supposed" 306. will check next weekend when i tear the motor down.
i picked up a set of gt40p heads this weekend and a ported cobra lower with a downs upper. i was thinking about having thumper port the heads and i will have them milled down to bump up the compression to around 10-10.5
i was thinking of using an accufab throttle body any particle size recommendation?
what headers work with the p heads? i would prefer longtubes
any gear recommendations?
cam recommendations for my mild set up?
any long tube will work with a p head, 3.73-4.10,
interesting i did not know that.
also the car is 5spd and emissions are not a concern....
The Boss is in
I would go with an ABC cam from Ford Racing even thou alot of people dont like them. F cam is what I would do from Ford Racing
The Razor's Edge
get some BBK long tubes
BBK X pipe with or without cats
flowmaster car back
4.11 gears
F cam
and your GT40 heads
with that it would make it interesting
flowmaster car back
4.11 gears
F cam
and your GT40 heads
car-back?
yeah that set-up with harland sharp 1.6's
and NOBODY SELLS THAT RATIO GEARS
4:10 STUPID B!T$H
It's got a Lincoln motor and it's really souped upThat Model A body makes it look like a pupIt's got eight cylinders, uses them allIt's got overdrive, just won't stallWith a 4-barrel carb and a dual exhaustWith 4.11 gears you can really get lostIt's got safety tubes, but I ain't scaredThe brakes are good, tires fair
please....like 2/3 times?
VHAT?????
The Razor's Edge
dude what the **** are you talking about.
lyrics from the song "hot rod lincoln", when he wrote 4.11 gears it just made me think of that song.
me to im like RE RE...yeah WT you idiot...not only did you write 4:11s...you wrote it with an "." no an ":"...stupid
you...not me!
1 - 20 of 42 Posts
