A little long but bear with me, okay?
First off, the car is my son's - he bought someone else's headache, and I'm trying to sort it out. '91 5.0?
Me? Not much of a Mustang man at all (mostly SB Chevy man), but I am a mechanic - diesel certified, licensed A&P, and have previously owned and kept running two EEC-IV Tempo's.
Here's what's in it so far:
'97 Mountaineer short block from salvage (8.8:1 comp, best I can find out)
Windsor Jr. heads
Ford Racing E303 cam shaft
JEG's rockers (not sure of ratio)
Trick Flow upper (75mm), spacer, and lower intake.
BBK/Edelbrock throttle body (65mm)
BBK CAK (75mm?)
EGR blocked
EVP locked to "full closed signal"
24lb/hr injectors
Fuel Pressure 40psi
Ford Racing shorty headers, HEGO's operational
Crappy H-pipe exhaust w/out CAT/CON's
T5? Trans (no VSS)
Okay, by now, you've probably started guessing some of the problems
Crappy idle, dies on decel, running rich, backfring through exhausts, "Bad" TFI/SPOUT symptoms.
(Don't ask me why the boy wasted $5,500 on this...I'm just wanting my Sonoma back!)
Anyway, what we've done so far:
1. Set valve lash correctly.
2. Removed, stripped, repaired, continuity ck'd, Ohm'd out, shot for shorts/grounds the ENTIRE EEC and injector harness (had them laid out in the living room floor).
3. Repaired any/all possible vacuum leaks to be found.
4. Replaced pos/neg battery cables, eng/body ground, battery/body ground, EEC/body ground (grounds replaced with aircraft grade bondings).
5. Removed, disassembled & cleaned IAC valve, EGR body, & throttle body (Lord were they cruddy).
6. Cleaned MAF sensor.
7. Reassembled/reinstalled all, cleared all stored codes, test ran, setting idle regulated fuel pressure to 40psi w/vacuum reconnected to regulator, and base spark advance to 14*BTDC.
Pulled new codes:
31 - EVP Ckt Below Min Volts
84 - EGR Valve Reg Ckt Failure
85 - Canister Purge Ckt Failure
(Yep, have a few things to pin out, now).
For his rough idle, I've found he's using 93 octane, so I told him to go back to 89 octane, due to the low compression ratio. Also found out he's running a 150* t-stat, and told him to put a 185* or 190* t-stat in.
I'm strongly recommending him to match all his air components to the same mm bore, (frankly, I think 65 mm is sufficient for a daily driver, 75mm a bit too much and too quick for 19-year-old) and to add a VSS to prevent any problems with decel lean-out/dying.
Suggestions? (No "hot-rod-racer" stuff, please).
Windsor Jr. heads
BBK CAK (75mm?)
EGR blocked
24lb/hr injectors
Fuel Pressure 40psi
T5? Trans (no VSS)
Pulled new codes:
