1 - 2 of 2 Posts
I would like to know from someone who has installed before nos and meth and windexing if you could explain how to install and if it would be better to go wet or dry on the nos application thanks! :-D
Wet is much easier than dry. Wet already has the fuel mixed into the spray. A dry nitrous system requires either a second bank of injectors, or large injectors and a proper tune both ways.
I know nothing about water meth injection.. But if you are doing it to run cooler temps at wide open, you can convert your fuel system over to a methanol injection. It runs twice as much fuel, but the cost of it is relatively cheap. If you buy it by the drum you can get it for close to or under $2 per gallon. Plus its 114 octane so it has incredible detonation resistance.
1 - 2 of 2 Posts
