1 - 6 of 6 Posts
Has anyone done a independent fuel system for a nitrous set up? Do you have any pictures? I was running a 100 dry Venom system, but now with my MMR motor I'm putting together a 250 direct port system.
if you have room just put a small 1 gallon fuel cell under the hood or in the trunk. You will need a pump that can push 40psi, the fuel line and fittings. Very simple and good insurance
Nitrous Outlet seems to have a nice pre made set up that fit in the battery box. I like it but 729.00 seem like a lot....Time to research...:cool:
What i would do is get a fuel pressure regulator set to 40psi, 1 gallon fuel cell filled with c16 race gas and a inline fuel pump to run it.
Find a aluminum cooler tank from a SC car and install where your battery sits.
I have the battery in the trunk of my 89 GT and I hated it.
Nitrous Outlet sells this kit. I'm pretty sure that's what I'll be running.
1 - 6 of 6 Posts
