1 - 15 of 15 Posts
ok soo some people know that i recently purchased a wet nitrous system anyone have any good right ups on installing a wet kit on a 99-04 mustang v6 or gt? pics and step by step would be nice...
thanks to all that want to help.....
thanks man u got anywrite ups for the nitrous install it self like solinoids and jets and stuff?
like step by step install like one that would come with a brand new nitrous kit just step by step directions on how to installa wet kit.
mm's nitrous mod
find a place where you want to mount the bottle
test fit and then mount the bottle
pull a rubber plug out of the trunk floor near the opening of the bottle
find location for nozzle
find location for solenoids, remember length of line from solenoids will dictate where the solenoids will need to be mounted
run the line from the bottle to the solenoid underneath the car. remember to to tie it up well and to keep it away from pinch points and heat scources.
mount the WOT switch
mount the toggle switch inside vehicle
(those with a msd digital window switch)
find a place to mount you window switch
run a switched 12+ wire to the window switch and toggle switch
run black wire form msd window switch to a chassis ground
run 12+ wire from toggle to WOT
12+ from WOT to solenoids
hook ground wire from solenoids to yellow wire on msd window switch
hook white wire to left wire on any coil
check all connections to make sure all are good.
turn on key
set window switch to cyl. 1, on set point of your choice, and off at your choice
arm system, make sure there is a 12+ at the wot switch from toggle with a volt meter
unhook wire from WOT to solenoids, close contact, and use volt meter to check for 12+ coming out of the WOT switch.
hook solenoid wire back on WOT switch, close WOT switch contact, cheack to make sure both solenoids are working
turn off key
install fuel fitting on fuel rail or install the frps adaptor
run fuel line from fitting/adaptor to the fuel solenoid
install jets for desired shot of n2o
go have bottle filled
unhook line off nitrous solenoid, and crack bottle open for a second of two to clear out the line.
hook line back up and make sure all lines and fittings are tight.
make sure bottle pressure is up to 950psi+ and take out for initial test run.
this is just general instructions. remeber that spark plugs will need to be change, tune may be required, fuel pump may be needed for larger shots, etc. supporting mods are needed, but this is just for the kit itself.
Discussion Starter · #11 ·
awsome man thanks alot if i have any problems 2morro ill contact u. thanks for being so helpful i just dont want to hook anything up wrong! thanks again
turn on key
turn off key
Thats a Pretty nice write up..considering you prolly just wrote that off the top of your head.
mm's nitrous mod
:yes i was at work too. it is only one way to do it. some people have a little different set up, but is pretty close to the same.
1 - 15 of 15 Posts
