I got my hands on a nitrous plate and have a system set up i wasnt sure if it was ok to run a 100 shot dry ? do the injectors add the fuel for you ?
yes, through the added vacuum it will pull in more fuel.
There is a window where the motor burns very lean, and your relying on your stock 20yr old injector's to do the job...... i don't like that.
some kit's tap into the fuel lines and such on a dry kit, like NOS (the company) does, and those are the only ones id trust, but you might as well just went with a wet shot by then.
Ive had almost no issue with my 100 wet shot through a single nozzle before the throttle body.
Had one nasty backfire that blew the intake gaskets and vacuum tree to hell, but that made me find out my motor had more miles then i knew about, and still had stock springs with 2 bent intake valves, and all the exhaust valves where pitted.
nitrous will help you find issues within your set up, that's for sure
