1 - 5 of 5 Posts
gtscrewd
Will this tire look funky an a 18x11 inch wheel it's the nt55r it says on the website it will work I just don't want that look of the stretched tire any advice? Reps have to make a decision ,the forge stars are almost done thanks
gtscrewd
cool i was haveing second thoughts theres a fine line between the bulge look and the rim almost sticking out from the tire cause its to small i want it to be right on
FBGM
Just remeber that nittos run small, I Know Udeaf had some nittos in either 315 or 305 and they were like the size of a 295
Just look at the pics I sent you. Those are 305 nittos on 10" rims. a 305 Nitto is just shy of 12" wide and would actually look much better on an 11" rim. They will be perfect. And don't worry about rubbing. I run the 305/45 without any issues with the same springs as you.
1 - 5 of 5 Posts
