1 - 20 of 31 Posts
I want to get some drag radials for my factory 17x8 wheels. I know some guys run a 275's on these wheels but they just seem a bit narrow for that wide of a dr. Will the 245 hook good enough for me at the track with the below mods?
2000 GT Automatic, 4:10's, SCT Tuner, MAC long tubes, MAC catless mid pipe, Flowmaster mufflers, BBK 70mm throttle body, UPR coil overs w/Lakewood 50/50's and 70/30's.
Let me know what the consensus is.
you'll be alright with pretty much any tire, but I'd go with the 275 nittos.
Casper, isn't a 275 going to not fit the 8" wide wheel though?
+1
I run 315 Nitto 555R's, but as long as you have the right suspension and get your launch down if you take the car to the track, it'll hook up nice. I have been getting consistent 1.68, 1.67 60's with the turbo, and my b/f runs 275 Nitto's on his 800+hp TT Cobra and it hooks up. :)
This has been a previous argument on the forum...it works, it's been done many many times (my b/f's 275's are on stock 17x7 rims), it's just not the 'recommended' tire size for the rim. If you take the car around tight corners on a road course or autocrossing, then you might have a problem with the 275's. lol
I would just go with 275's. i had some on my 96 style wheels which were 8" wide and they didn't hang over much. nitto's are sized small so it's not that bad at all. with a 275 and your mods you'll have no problem hooking on the track or street after a little burnout.
it will buldge a little & is "technically" not recomended, but there are tons & tons of people running 275/40's on 17x8's.
look around for some pics & you can make a better decision.
I switched from 555r to nto5r and they do much better. So the nto5r has my vote for a track tire.
Yes, they are no doubt a better tire, but it's a completely different/softer compound. If the OP is looking for something that would also work on the street or DDing, then the 555R's are the way to go...they last at least 2-3 times longer than the NT05R's. :)
anyone know how long n555r's last. getting some 10th anniversary cobra's (black w/chrome lip) to swap out on race day. contemplateing between n555r's, nt05r's and the mickey thompson's they offer on American Muscle
you'll need the mickey thompsons, skip the nittos
Abyssinian of AX
A 275 on a 7" wide wheel is not only a LONG way from "recommended" but well beyond foolish :(
I just bought 275 NT555Rs for my stock 8" wheels and they fit fine. They hook really really good. I have 0 complaints about them.
BYAHHHH!
at the track with 4:10s I hooked on 18's with normal 555's
a 245 with a stock stall will more then likely hold you
Discussion Starter #17
Wow, great responses all, thanks so much. I am going to look into the 275s when it comes time to bite the bullet. Anyone know the absolute cheapest place to get some? What would a tire shop like Discount charge to install them in the rear wheels?
Discount tire direct sells the 245 NT555Rs and 275 NT555Rs for the same price, $153 each. or they did when I was searching. Cheapest I could find them, and free shipping
+1
275s with an 800hp car?.... I'm running 370ish rwhp and my 555s in 315 are a ****ing joke in 1st and second.
Discussion Starter #20
I saw them there last night. That is pretty darn cheap in all reality. I think I may need to pick up a couple of them before I hit the track next. After tires will come control arms. After control arms either a stall or Bullit brakes.
1 - 20 of 31 Posts
