1 - 20 of 38 Posts
checked my tires today(nitto 555r's)and there already worn down to the indicators on center of tire,only got 2k miles on them,just wondering how far you guys run yours until you replace them?
wow, only 2k miles? do you go to the track alot?
thats what i thought wow,i thought they last about 13k miles,i've only been to track twice a total of 7 runs and the last 4 runs i burned the tires until they started to smoke and quit and everytime i take it out i'm always getting on the throttle but i never burn tire other then track.
I run them bitches bald.. lol.. I get about 8k from mine.. 315/35/17s..
thats what i plan on doing(run them bald) but at the rate i'm going i'll never get 8k miles but then again the wear indicators on the nitto's new are not that far away from surface
I have no clue how long mine last. I only used mine for the track.
Admanistrator
When I get wheels, I want a tire that I can get several years out of (30-40k miles or so), but still give good traction. Am I dreaming?
well i just got my first set but they are the regular 555's not the r's i hope they last
Abyssinian of AX
Seems as though you've been "accelerating" A LOT :shiftyeyes
I have nearly 10K on my R888's and the fronts are just passing the warning indicators and rears are not quite there. Been to approx. 10 AX days and spent a couple hours running around Infineon.
I typically run my fronts down well before my rears and such is the case here.
Jazzer :)
Discussion Starter · #18 ·
Jazzer :)
i do get on the car about everytime i take it out maybe thats why there low but still i thought they would last longer then this but i may have a few thousand left on them the indicators are only flush at center of tire
Abyssinian of AX
If indicators are ONLY flush at the center of the tires, lower the pressure a couple LBS :yes
Jazzer :)
1 - 20 of 38 Posts
