1 - 6 of 6 Posts
My friend is into imports so we took his Miata to the dyno for a base run and for some reason it's showing zero hp? Maybe someone has had a similar issue with these cars? Any help would be greatly appreciated. I took a pic if that helps?
part of the problem is that the roller is on the wrong end of the car. you'll need to have a crew come and move the roller to the back wheels. unfortunately that will probably be a major pain with the car in the way, but i can't see any other way of doing it. my personal opinion is that it's not worth all the work though, because even if the roller is moved, it will still show the same hp rating after a pull if it's calibrated correctly.
I found that pic and I think they were going try and dyno it that way. I wonder if they tried to do a run before they figured out the problem
It seems weird to go through all the trouble of strapping the car, having the fun up there, etc, just to take a crappy phone pic for a joke haha
1 - 6 of 6 Posts
