That's getting pretty hot, assuming it's working properly. Mine stays at the A usually and never touches the M
Yes it could, the water pump won't spin as fast so it's not moving the same amount of coolant as it would with the stock pulley.could an underdrive pulley cause overheating
So wats the point having UDP its not even worth the power u free up then rightYes it could, the water pump won't spin as fast so it's not moving the same amount of coolant as it would with the stock pulley.
