1 - 3 of 3 Posts
I purchase nx-wet plate system...it said min.45 pounds fuel presure.doest that sound right..I install svt fuel pump..will that be ok...
mm's nitrous mod
it will be fine. the usual fuel pressure is around 43psi and maxes around 45. the focus pump will do just fine for most. i did a little research on the focus pump and a few have had problems with high rpm's and higher psi with their pump. seems the focus pump dont like to give more than 45psi for a prolonged time. i am still on a stock fuel pump and sprayin 125 thru my plate, my fuel pressure is constant 43-44 psi.
not to be a dick, but THE CORRECT TERM IS NITROUS, N2O, JUICE, ETC. nos is a brand, and is not a shorter version of nitrous!
1 - 3 of 3 Posts
