1 - 3 of 3 Posts
Hello,
I just bought a 99 mustang GT and on the same day bought a supercharger not Knowing it was a novi 2000, which with the wrong pulleys I know it can destroy my engine. I just wanna know how to get a solid 550-650hp with 6-10lbs of total boost. I know I gotta reinforce my suspension but I don’t wanna blow up my engine. Just wanna know specs to make it do what I want lol
thank you,
p.s got the whole kit at a steal of 800 and it works
BoostedGT
If you want that much power you will need a lot of work. it can be done but is a time bomb with a stock bottom end you will need to new cams, injectors possibly even heads and more boost if you want that kind of power. I would not go over 10 pounds of boost if you want to be safe and I would say your lucky to hit 400Hp.
10psi plus blower cams will get you around 470rwhp. That's about all you want to push on the stock bottom end. I'm at 508rwhp through an auto on a stock longblock Mach motor, but I wouldn't recommend it if you're worried about blowing the stock motor.
Sent from my IN2015 using Tapatalk
1 - 3 of 3 Posts
