is there a rubber o ring on the breather?
....I think breathers are a bad idea... THe pcv needs to do its job.
Right...I think breathers are a bad idea... THe pcv needs to do its job. If you must run a breather then you should stuff something like a shop rag or steel wool into the filter to help stop any oil, but once the "stuffing" is saturated it will leak again, i have a vacuum pump on my motor and it runs into a breather that i have to empty after 5 runs and ring out the shop rag i stuffed in it..
No sh**. I've cleaned mine twice...once when I found it dirty during an attempt at installing a CAI, another for a computer code, and I'm due again in another 10k miles or so...yikes.....
Ever see the butterflies of an engine that's had a PCV system doing its job for 25k miles?
The PCV is still doing its job with breathers. The PCV valve is actually in our valve covers. Anyways, all the breathers do is change where the gases are coming from and going. The crankcase is still getting vented of any positive or negative pressure. In theory, negative crank case pressure, even though it will never be as high as positve pressure, is just as bad for your motor.I think breathers are a bad idea... THe pcv needs to do its job. If you must run a breather then you should stuff something like a shop rag or steel wool into the filter to help stop any oil, but once the "stuffing" is saturated it will leak again, i have a vacuum pump on my motor and it runs into a breather that i have to empty after 5 runs and ring out the shop rag i stuffed in it..
Posh, unsubstantiated heresy.Catch can with closed PCV system FTW
