1 - 13 of 13 Posts
Ive read that its supposed to come off from the oil pump. Now do i have to tap the oil pump or is there like a splitter i would use, i should be getting my oil lines soon from Superchargersonline.
Thanks
you dont tap at the oil pump, you put a T off your oil pressure senser located on the neck where your oil filter screws on. the part you tap is the oil pan, but im sure you know that.
Did you go with the red feed line or did you upgrade to the stainless? I have the red line and am really thinking of going to the stainless.
i went with the red, i was gunna go with the stainless but its really not worth the 80$ right now, ill prolly upgrade down the road,
whats wrong witht the read feed line? haha
They leak. Not alot, but just enough to notice if you run your finger along the bottom side of the line.
BYAHHHH!
does anyone have a pic of the t in with the oil sending unit?
This is the best pic I have. You can see the brass fiting coming off where the oil filter sits.
  • Like
Reactions: Scott2001GT
BYAHHHH!
hey man thanks a bunch!
1 - 13 of 13 Posts
