1 - 3 of 3 Posts
I have a 83 2.3turbo in a 29 A I just got oil in my water 147 to 150 PSI. on all cylinders. pulled head and hard to tell if head gasket is bad not blowen at fire rings maybe it is my oil coolernot sure .not running hot .trans line to rad. undone. where is the oil comeing from.
Oil in the coolant, or vice versa, is usually a bad head gasket. Could be the head not torqued properly, or if the head or block have been machined at all, one or both surfaces may be uneven. No idea. Post a pic of what you are seeing.
I pulled the oil cooler and had it tested it was bad. right now i am not runing a oil cooler. it takes a long time to clean out all of the oil. thanks for the help. i will post when i start driveing the car full time still alot to do.
1 - 3 of 3 Posts
