1 - 5 of 5 Posts
Where is it located on my 2005 mustang 4.6.
Discussion Starter · #2 ·
im trying to hook up an oil pressure gauge i just want to know the best place to plug it in. thanks
i think its the one by the filter... i think...
yeah its buy the oil filter, just get under the car look at the oil filter and you will see a wire that is going down by the oil filter that is the oil pressure sensor, i did a oil pressures on my 06 gt, just make sure you use telfon tape and the hoses are TIGHT with the clamps, the first time i did it one of the hoses let go for some reason and oil went everywhere, and i would suggest reusing the stock dash oil sensor too, just in case, ya know.
you just get a t fitting, some hose, and clamps. if you do deside to use both, you are going to have to relocate them some where cause the after market senor a t fitting and the stock sensor dont fit in the little space that you have, if you want i can get some pictures of my set up.
1 - 5 of 5 Posts
