1 - 16 of 16 Posts
Hope someone can help . I have a 1990 lx 5.0 , I blew a head gasket and dumped a crapped load of water into the oil , well I pulled the heads replaced the head gaskets and opted for a set of GT40P heads from a 98 mountianeer . I flushed the engine pretty good with fresh oil while I had the intake off . When I got it all back together it ran better than ever , with one exception , my oil oil pressure was only running around 20 psi . Prior to blowing the head gasket it was between 42 to 50 psi . So I replaced the main and rod bearings and oil pump and went to 20w50 oil and it jump to around 40 psi , but after running for about 30 to 45 minutes it drops back down to around 25 psi except under accelaration . I strongly suspect the cam bearings , but that is alot of work , does anyone know of a way to get the pressure back up without replaceing the cam bearings and rebuilding the engine ?
Edit Report
Resident Know-it-all
How long did you run it with the blown headgasket?
i would just like to get the pressure back to a safe level for now so i can drive the car every now and then . i plan to rebuild the engine and transmission soon , but with christmas and a wife and 3 kids sometimes extra money is hard to find
that is a safe level
I can rebuild the engine for under a thousand , but if i'm going to do all of that i want to swap out the cam , switch to a steel forged crank and keith black pistons . but all of that costs extra .
Maybe it's just me but 40 psi at idle seems a bit high. Your numbers seem fine to me.
I would only use a high volume with a 7qt pan
1 - 16 of 16 Posts
