my car has 195000 miles. i think its burning a little bit of oil. should i switch from 5w-20 to 10w-40?
the manual says 6 quarts of 5w-20...a '99 (with the original motor) should have 5w30 in it, not 5w20, to start off. from what your saying now , the oil is leaking, not burning & oil weight will not help that, sorry. as to upping the weight, you shoud be ok with 10w30 in your case (ie. high mile's, high temp.). due to the very tight clearance's in these motor's, very heavy oil is a bad idea.
why 5w-30 and not 10w-30 like he posted above? what will the semi-synthetic do? any recommended brands?no all the 4.6s and 5.4s use 5w-20. go with a 5w-30 semi syth.
re read your owner's manual, & make shure it's for the right year (ie. the year of your car) as windsor motor's (which is the motor in a '99) take 5w30, romeo's take 5w20.the manual says 6 quarts of 5w-20.
if your not gonna fix the leaks, try non synthetic 10w30.it says 5w-20 in the manual... its the manual that came with the car when it was bought in 99.
can yall just recommend an oil for the next oil change, thanks
everyone's gonna have an opinion on something like this, there's not one fit's all answer. the one thing that can't be stessed enough is that synthetic oil (semi or full) will make leaks worse, other than that you'll have to make your own mind up. rthe reason I say 10w30 is that (regardless of anything else) a windsor motor take's 5w30 oil (all of them, if your manual say's diffrent, like I said check the vin# in your owner's manual case & make shure it's the right one & if it is, the 5w20 is a miss print) & 10w30 is a logical step up.hahaha, so one of yall says non-synthetic 10w-30 and the other says semi-synthetic 5w-30... awesome lol
wrong, sorry. romeo's yes, windsor's use 5w30 in car's & trucks, till the windsor plant went 3v & even then some 3v windsor's still use 5w30.all of the modular motors use 5w-20. for that just about all the ford motors use 5w-20 after 1996.
that would be the logical choice.find the leak, fix it, then put whatever you have been in it.
