1 - 6 of 6 Posts
I know I could go to the auto part store and buy a couple gaskets to compare, but I figure one of you gear heads already has the gaskets and wouldnt mind taking a picture of them for me.
I would like to lay a 1 pc header gasket for a 289 on a 1 pc header gasket for a 4.6
I am interested in how similiar the port locations are on the 2 engines.
I cannot find a tri-y header for my SN65C and am thinking of using a header for the 1965 289 application and changing the flanges to the 4.6 along with a bit of tube modification.
Thanks!
US Air Force (retired)
I doubt that they would be anywhere close. The old 289 had a 4" bore. Our mod motors have a 3.55" bore.
bore diameter is not a concern, the bore centers is what determines the spacing. I did a bit of searching on the web and found the bore centers are 7/16 wider on the 289.
Looks like it maybe a doable project when I get to that point.
thanks for the reply.
The reason the bore centers are wider is because the bore is bigger. How could this possibly work? 7/16th is a lot and by the time to add that to 4 cylinders its 1 3/4". Maybe I misunderstood your question but I thought you were asking how to put a 289 exhaust gasket on a 4.6L. It won't fit its too long.
I said "I cannot find a tri-y header for my SN65C and am thinking of using a header for the 1965 289 application and changing the flanges to the 4.6 along with a bit of tube modification."
That means just what it says, cut off the flanges from a set of 289tri-y headers and adapted the tubing to fit a set of 4.6 header flanges. Each of 3 tubes will need to relocate 7/16" or a combination of and also address the other clearance issues .
Thanks for your reply.
Ahh. Good luck with your mod. Let us know how it turns out.
1 - 6 of 6 Posts
