1 - 16 of 16 Posts
· Registered
Ok Mustink:D I want to hear what you think (and others) about the cam I decided to go with for my 347 build. Heads: TFS-51400004-C01 Cylinder Heads, Twisted Wedge® 185, CNC. TFS Track heat Intakes, and all the other BS supporting mods and fuel upgrades Harland 1.6 rockers. etc ask if there is anything I left out.
the cam:
net lift .570 intake .568 ex - 114.07 lobe separation ...if you want more numbers I will post them just let me know.
· Banned
the cam:
I am no cam expert.....
Need alot more info.... Compression, h/c/i, Where you want to shift, exhaust etc etc....
Do you have a cam card? What core is this cam?
· Registered
Discussion Starter · #5 · (Edited)
haha thats exactly why I picked it cause its "HUGE" LOL I didnt make this to be a prick I just wanted to see what some of you would say cause everyone has such strong opinions on cams but nobody has said anything which really suprises me
SADI core shift around 6-6500 10.5:1
· Banned
Didnt say your a prick....
Need a lot more info on the combination and the cam to tell anything....
· Registered
I know you didnt say that but I am sure some people will think it but whatever I have never been one to care much about other peoples opinions of me :D so why start now..LOL added 10.5:1 compression what else you want to know I will post it
· Registered
Discussion Starter · #12 · (Edited)
Well I am suprised this thread hasn't had a ton of posts and arguments like most cam threads go. But one thing I was trying to get across .... A cam should be the LAST mod you do. You have to know EVERYTHING about the car in order to get the cam right. This month has been full of new kids coming here and asking whats the biggest cam they can put in their NON modded car cause they want it to sound cool.....sounding cool doesnt mean running good kiddos.
· Registered
A way to look at it: A cam is like a rear gear, you have to have a goal to attain, or some direction. You want power to build to the shiftpoint, and you want it to still make power around the rpm you cross the line at, while at the same time making as much average hp as possible.
· Registered
Discussion Starter · #14 · (Edited)
Ok its a stock block (right now)
TFS-25002 - 255 LPH FUEL PUMP
TFS-21406700 - PUSHRODS
TFS-51400904 - GASKET KIT
TFS-51400801 - VALVE COVERS
TFS-51400004 - HEADS CO1's cnc ported 185's
TFS-51500002 - INTAKES
TFS-51400800 - OIL FILLER
TFS-51478520 - TIMING SET
TFS-5150SN95 - INTAKE SPACER
AEI15633 - FUEL PRESSURE GUAGE
AEI13102 - AFPR
SUM29055C-C - 75 MM MASS AIR FOR 30LB AND CAI
BBK1524 - 75 MM THROTTLE BODY
FORD RACING 3:73 GEARS
FMS-M-9593-B302 - 30 LB/HR INJECTORS
Harland Sharp S4302 - Harland Sharp Roller Rockers
BBK EQUAL LENGTH CERAMIC COATED HEADERS
- CHP 347 STROKER KIT (ROTATING ASSEMBLY)
- CAM
- TRANSMISSION REBUILD W/ upgraded part and built 4r70w VB
- 2800 STALL
now the cam:
CI - 347 SBF
Cam Type- Hydr. roller (SADI core)
firing order -STD 351 w/ 302 HO ford
Cam bearing- STD 351 w/ 302 HO ford
lobe separation - 114.07
overlap @ .050 -2.87degrees
MEASUREMENT INTAKE EXHAUST
duration @ .006 272.20 284.04
@ .020 247.16 259.01
@.050 219.45 231.10
@.200 143.17 152.37
lobe lift .35632 .35479
roller rockers 1.60 1.60
gross lift .570 .568
lash HOT HYD HYD
net lift .570 .568
lobe centerline 112.30 ATDC 115.84 BTDC
open @ .050 -2.58 BTDC 51.39 BBDC
close @ .050 42.03 ABDC -0.29 ATDC
lift @ TDC [email protected] in center .0587 @ 115.84 ex center
Crank compression 192 psi
Vaccum at idle 15.9 inches
Idle RPM 800RPM
Peak Torque 4300 RPM
Peak HP 5600 RPM
start shift point 6300 RPM
starting RPM to cross 6600 RPM
· Registered
Discussion Starter · #16 ·
That I don't know, was someone else that decided that was the way to go. I do not know much about cams so I put it in his hands with confidence he would make the right decisions. Its a little lopey, sounds great, but very street friendly.
1 - 16 of 16 Posts
