1 - 12 of 12 Posts
i tried the svt room so i decied to post it here also, i will post pics also, but the other day i remove this gauge cluster but the as soon as i popped it off the lock or nut, w/e was holding fell back, i removed the radio, but still couldnt find it, any ideas on how to get it, or a way to hold the gauge cluster? btw, its a 1999 cobra =)
do you possibly have something magnetic you can stick down the hole? It's possible that the nut in question is sitting on top of the a/c duct if I'm thinking right.
Its also likely that it fell a good ways and could have landed either on your floor board, under your radio, further back behind other stuff, or underneath everything next to your tanny tunnel. A magnet would help.
yea, i've looked around and cant find it, you know what they say when you want something you wont find it until u dont need it lol... but yea i look around those areas thanks bro
April 2012 ROTM
you def have a dash problem...there is a hole under your gauge pod! lol your best bet is to get a magnet and poke around....i have found a few things that I dropped back there with a magnet
Safud: MM's Resident Hadji
Remove the 2 bolts under the center panel. Then you should be able to take off the bezel. With the bezel off you should be able to pull out any of the components in the center dash to gain access to wherever you dropped the piece
Its been a long time since I had the stock radio.. but I thought you couldn't take the radio out without taking the bezel out. Meaning, didn't he already do that?
April 2012 ROTM
taking out all the bezels and stuff is no big deal...jus take your time and dont force anything lol
there is also another bolt inside the cavity that holds it to the firewall.
1 - 12 of 12 Posts
