1 - 16 of 16 Posts
I got a 4.6 DOHC out of a 2001 lincoln continental for free, its one of those gay ass FWD cars. It is all aluminum, both the block and the heads are. I was looking at the bell housing on the engine and it looks to small to go in a mustang. Will the heads or the block work on a mustang?
im pretty sure its RWD. im pretty sure its the same chassis as the crown vic and maruader....do get others' opinions tho.
I got it from my friend that works at a dealership and he said it was FWD.
I think so, I'll post a pic later today of it.
Resident Bubblehead
if it came from a Lincoln Continental, it's a FWD block. it has different coolant flow, extra bosses for engine mounts and a different bellhousing pattern. you can't bolt a RWD tranny up to it, at least as far as i know...
MM's Mad Scientist
OK. maybe I am wrong. I thought all modualar blocks had the same bellhousing pattern.
Are the heads the same?
I think Lincoln Continental's are RWD but I could be wrong.
amateur adult film star
ooooooooooooo doc just hit you with a spec sheet
1 - 16 of 16 Posts
