i was out screwing around and decided to play around with shifting styles. and of course i screw something up, and heres the pic:
What the hell did you do?
oops, n2o backfire
My bad. Let me be more specific. Do you know what caused it too backfire?
Mine had a couple of small holes:yeshaha, mine looked worse on the dyno, the whole front of my intake was gone
Do you have a wide open throttle switch? Were you powershifting?i have a window switch, just trying to shift a little earlier to see how the car took to it. i found out quick. machboy came down for me to do some port work, took him out for a ride to get a small break from porting when this happened. this could set me back a little on my build. i just put my old plastic x-over back on. i not to sure about the typhoon, thinking about the hardballr, trickflow, or bbk if it ever comes out. i didnt really like the typhoon after dealing with it, but i am willing to give it another shot.
:yes was working fine, then tried shifting a little earlier to see if any better results.Do you have a wide open throttle switch? Were you powershifting?
