1 - 20 of 29 Posts
Isn't that just a blank code if you have a tune? Like the CEL light isn't on its just in the memory? My diablo always saw that code!! But my sct doesn't... so who knows. I think thats the p1000 code, not positive though. So somebody else can chime in :D
I know for a fact that it can be gotten rid of. I just need to know if I have to start over or if it will eventually go away.
yeh i have become good freinds with this code it comes a gose as it likes ,, i think it has to do with the cycle of the pc when its testing just meen the cycle is not finished
I already did the entire cycle and portions of it multiple times though.
It does go away. If you cant get it to reset after one drive cycle (as you listed) you do have to park the car for like 8 hours and do it again. DO NOT reset it and start over. I have seen this code take anywhere from 20 to 500 miles to reset. Its a pain, but just stick the drive cycle.
I just parked the car for 8 hours but I drove it a little bit already this morning. Do I have to wait another 8 hours and then do the cycle immediately upon starting it after the 8 hours?
hardhitter... i had this code popping up on the regular with that tune i got from Houston performance along with other BS codes. My good tuner got rid of it all and ive never had a code thrown and never seen that p1000 code again. Your tuner can get rid of it.
ive heard the driving cycle usually never gets rid of it.
Discussion Starter · #11 ·
I don't want the tuner to get rid of it because I need it to go away to pass inspection and he knows that. I don't have a houston performance tune anymore. It's the only code that comes up and I've got it to clear before when I had my last inspection, I'm just having trouble this time.
you wil need to find out which readiness monitor is not set to get an accurate remedy. you must have a tune with all the obdii stuff turned on(rear o2's etc). the hardest one to set is the evap. monitor. you will have to clear(reset) computer,must have 3/4 to 7/8 tank of fuel, car must be cold(intial start-up),aits below 100* and cruise at a steady speed(60 mph) for about 10 miles.
as far as I know a tuner cannot get rid of the p1000 code, besides most insp. also check for the monitors being set as well as no p1000
Edit: noticed you have no cats,you will not set the cat eff. monitor. will need to put cats on car with the rear o2's on
limited... then how did my tuner get rid of it and the other 7 or 8 codes that Houston Performance left my car with? P1000 was one of them and it was like that for about 2-3 weeks. Never came back on after he tuned the car.
you sure it is gone? it does not set the check eng(service eng) light. are any of your monitors set? I am not saying I know for sure it can't be removed, just never heard of it being done
dont know. I have had my xcal pluggd up and nothing showed up. CEL light is never on so im assuming its gone. Car is as normal as ever.
Discussion Starter · #16 ·
I have the cats on right now. He turned all the obdii stuff on but I don't know how to find out which readiness monitor isn't set. I already failed my inspection once so I only have one more try.
It was the other 7 or 8 codes that was keeping the p1000 code on. During a drive cycle if any trouble code is tripped, the monitors will NOT reset (p1000 will stay on). so once they turned off the other 7 or 8 codes, the system was able to reset and clear your p1000 code.
+1 what he said :D
1 - 20 of 29 Posts
