1 - 13 of 13 Posts
:shiftyeyes
replaced the cam shaft sync and sensor bout 4 months ago
i googled it and took it to auto zone to see what the code was, everything is saying cam shaft sync / sensor. could it really go out that quick?
If you have a tuner, you can clear the KAM (Keep Alive Memory).. or you can disconnect the battery for 20 minutes.
V6 BIOTCH
P1336 - Crankshaft/Camshaft Sensor Range/Performance
Description: The input signal to the powertrain control module (PCM) from the crankshaft position (CKP)
sensor or the camshaft position (CMP) sensor is erratic.
Possible Causes: • Damaged CKP sensor
• Damaged CMP sensor
• Base engine concerns
• Harness concerns
Diagnostic Aids: Check the harness for routing, alterations, improper shielding, or electrical interference from
other improperly functioning systems.
Application Key On Engine Off Key On Engine Running Continuous Memory
All — — GO to Pinpoint Test JD.
:shiftyeyes
Discussion Starter #13
• Harness concerns
Thanks mike, reps when i get to a computer
check your plugs on both crank and cam sensor.
My cam sensor plug isn't the right right, so It likes to slide up and **** up the signal. So I taped da fuhq out of that thing :D
Damn race car to fast to keep a ****ing plug on its cam sensor -_-
1 - 13 of 13 Posts
