Was thinking of this product
VHT FLAMEPROOF™ Coating will renew and extend the life of any surface exposed to extremely high temperatures. This unique coating is widely used by the automotive industry on exhaust systems, and the aerospace industry for jet engines, re-entry vehicles and other high temperature paint applications.
Temperature1300°F-2000°F (704°C-1093°C) Intermittent
Dry TimeCuring time required and can be done on or off vehicle (see below).
ApplicationsHeaders, Exhaust Systems, Piston Domes, Inside Heads
Curing FLAMEPROOF™ VHT FLAMEPROOF™ Coating only attains its unique properties after correct curing (refer to instructions on the can).
- On the Vehicle
- Paint must be completely dry before curing
- Run at idle for 10 minutes
- Cool for 20 minutes
- Run at idle for 20 minutes
- Run under normal operating conditions for 30 minutes
- Off the Vehicle
- Heat to 250°F (121°C) for 30 minutes
- Cool for 30 minutes
- Heat to 400°F (204°C) for 30 minutes
- Heat to 650°F (343°C ) for 30 minutes
