Hey guys
So my Auto KB 2001 GT has a very rough time accelerating immediately after the shift into 3rd gear.
It almost appears that the rpms drop too low. The rpms drop to around 1400-1600, and if I apply pressure to the pedal, the car runs like crap and rpms do not increase until I gove it heavy gas and it takes off (no noticeale pinging or knocking, but the symptoms of detonation kind of?). I can hear it running like **** by the sound of my exhaust.
Now here’s the weird part. When I drive in the morning to work, the first 3-4 minutes it doesn’t do this at all. 3rd gear the rpms stay nice and high and if I suddenly accelerate, the car goes great. Only after 5 minutes of driving the symptoms start. Also, the symptoms seem worse in the rain.
I assumed the issue was o2 sensors not working via open/closed loop. Unplugged the sensors and took it for a quick drive, symptoms were still there.
Here’s what I have done to find the problem to no avail:
Unplugged (New) oem o2 sensors
Unplugged entire EGR system
Unplugged tps
Cleaned Maf
Cleaned IAC
New COP Boots
New Fuel Filter
New DW 340 lph fuel pump (oem died)
So do you guys think this is a trans issue? Should I change fluid?
I am thinking either trans, bad msd cop(s), or a bad tune.
What else would cause an issue after being warmed up?
No idle issues, no wot issues. Just accelerating after the shift.
Also if i keep the car in 2nd gear, i have no issues at all.
Unplugged tps
Cleaned Maf
Cleaned IAC
New COP Boots
New Fuel Filter
