1 - 6 of 6 Posts
Manthusiast
So I figured out my amplifier issue.
Not even a week later now my passenger side widow wont go up.
It wont go up when I use the drivers side, but itll go down.
The passenger side switch is out.
Any suggestions?
check the harness by the door jam and the switches is all i can say to that. a bad switch on one side can be messing up the other since they are tied together .
Manthusiast
Its worked up until now, working on replacing motor.
its a hassle ill finish tomorrow
When my passenger side window stopped working I took it apart and filed the crud off of the contacts inside the switch, that worked for me. My driver side switch did roll the window up and down tho. Is the passenger switch possibly getting stuck internally?
From the symptoms you've described the problem is most certainly your switch and not your motor. Though depending on the age of the motor, it could have a compounding affect on your switch. Start with changing the switches... I diagnose and install motors/switches/regulators for a living. Hope my post wasn't too late to not still be useful.
1 - 6 of 6 Posts
